1999 Chevy Blazer Won't Start
LAURAANNMEISEL
First of all I have a remote starter on my Blazer and last night I started it with the remote. When I turned the car off and took the keys out, it kept running. So I took the cables of the battery and it kept running. I finally pulled the engine fuse and the car shut off. Now my problem is that it won't start. Please help me!
Feb 24, 2007 at 6:59 AM
CHEVY22
  • 1,375 POSTS
hmmmm, your remote start should have a module under the drivers side somewhere , locate it and remove it , and see what happens and let me know , i monitor the posts i respond to
good luck
jim
Feb 24, 2007 at 10:01 AM
MIKE H R
  • 3,094 POSTS
try first dis-connecting the wire or take out fuse from the remote starter. with a remote starter could be active keeping it from starting
Feb 24, 2007 at 10:05 AM
Suggested Repair
Locate the remote starter module under the driver's side and disconnect or remove it, or pull the remote starter fuse and disconnect its wiring. Then try a normal start, since the remote starter may still be active and preventing the engine from starting.
Conversation Summary
A 1999 Chevy Blazer with a remote starter kept running after the key was removed and even after the battery cables were disconnected, until the engine fuse was pulled. It now will not start. Advice is to disconnect the remote starter module or its fuse and wiring, then retry starting, because the remote starter may still be active.
