1998 Chevrolet Blazer No-Start in Rain
ROGER86
I have a 1998 Blazer with 212,000 miles. It won't start when it's raining. It cranks and cranks, but won't start. It starts fine when the rain stops and everything dries out. Where should I begin?
Dec 27, 2006 at 12:54 AM
WHITEMAGI
You probably have moisture getting to the coil wires. That would cause that probably. Just use silicone grease to seal up the connections to keep the moisture out
Dec 27, 2006 at 4:13 AM
SERVICE WRITER
  • 9,123 POSTS
I agree with the probablity of the wires. Unless they are somewhat new, I'd replace them.
Dec 27, 2006 at 9:59 AM
Suggested Repair
Inspect the ignition coil wires for moisture intrusion. Seal the connections with silicone grease, and replace the wires unless they are fairly new.
Conversation Summary
The owner of a 1998 Chevrolet Blazer says it cranks but will not start in the rain, then starts normally after everything dries. A reply suggests moisture is reaching the coil wires and recommends sealing the connections with silicone grease. The expert agrees the wires are the likely cause and advises replacing them unless they are fairly new.
