1998 Chevrolet Blazer No Start
TRICIAVIGIL
I have a 98 Blazer. My dad tried to start the a/c clutch by hard wiring the a/c clutch to the fuse box. The a/c clutch engaged for a minute but then stopped. The Blazer was running at the time. After the Blazer was shut off and tried to restart there is not turn over. Was able to start it a few times with a screwdriver to the starter but now it's not starting like that either. It tries to start by shorting the starter but then dies. Does this have anything to do with the anti theft system? Please help.
Jul 2, 2006 at 6:47 AM
MIKEYBDMAN
  • 623 POSTS
Ok, first off, if you havent done so by now, undo what your dad did. Look to see where in the fuse box he attached the wires to, and try and isolate that circuit. Test each fuse to see if they are blown.
Most likely what happened is he bypassed the fuse by connecting to the hot side. What ever circuit he attached this hard wire to, probably fried a control or wire somewhere.
Good luck on fixing this, but hopefully a lesson was learned.
Jul 8, 2006 at 10:22 AM
Suggested Repair
Remove the hard-wired A/C clutch connection, identify which fuse-box circuit was tapped, and test every fuse. A hot-side bypass may have damaged a control or wiring; repair that circuit before further start attempts.
Conversation Summary
The owner said a 1998 Blazer would not crank after the A/C clutch was hard-wired to the fuse box while the engine was running. Jumping the starter worked briefly, then failed. The expert advised undoing the jumper, isolating the tapped circuit, and testing fuses because the bypass likely damaged a control or wire.
