1998 Lumina Wont Start
EDX4212
  • 1998 CHEVROLET TRUCK
1998 Chevy Lumina - 210K Miles wont start. No spark is aparent. Fuel Pressure is good. Car cranks fine. No codes being registered. There wasnt any noticable issue before the last time the car was turned off. Car was very reliable! Im thinking its something really simple. Tried changing ignition and crank sensor. That didnt work. I know this car is old and used. But any input here would be appreciated. Thanks!
Tuesday, June 20th, 2006 AT 2:12 PM
SYNCRAIT
  • 235 POSTS
Grab your spark plug wires while someone turns over the engine if you feel a mild shock replace your wires if not check your distributor cap for build up on the terminals also im sure you changed your plugs. Good luck :)
Tuesday, June 20th, 2006 AT 4:30 PM
EDX4212
I have 3 coil packs. All of which arent firing. This is really driving me crazy. Any other thoughts? Find a deep lake?
Friday, June 23rd, 2006 AT 7:52 AM
