1998 Chevy Truck won't start
OL'BLUE
  • 1998 CHEVROLET TRUCK
  • V8
  • 100,000 MILES
I have a 1998 chevy diesel pick up. The starter is 2 yrs. Old. The allernator checks out good as do both batteries. When I try to start the truck the only thing that happens is the horn honks. Any help would be greatly appreciated.
Thursday, December 18th, 2008 AT 2:18 PM
JDL
  • 16,098 POSTS
Are the battery cables/wires all clean and tight on both ends?
You can do some testing at the starter relay in the power distribution center under the hood. Unplug the relay, use a testlite, have a helper turn the key to crank, two of those terminals should be hot. Testing at the relay should be easy, even if it leads elsewhere.
Just a thought, if this is an automatic, did you try cranking in neutral?
Thursday, December 18th, 2008 AT 3:18 PM
