1998 Chevy Truck Won't start
JOHN MOLL
  • 1998 CHEVROLET TRUCK
  • 6 CYL
  • 13,700 MILES
Ran fine, then 2 hours later wouldn't start. Turns over as normal acts like it is either not getting spark or fuel. Fuses are OK, that I can check visually, no other electrical issues - lights, radio, gauges, etc. Acts like it is not getting spark or gas. Gas gauge shows half a tank. Vehicle is in great condition and never have had any problems with it
Saturday, January 31st, 2009 AT 3:49 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, January 31st, 2009 AT 3:53 PM
