1998 Chevy Blazer Dim Headlight
KCMANGOLD
1998 Chevy Blazer LT 4.3v6 4x4 140,000mi. I have dim lights on the right (pass) side of the vehicle. I have checked bulbs and replaced sockets thinking maybe a grounding issue but problem still exists. Is there something else to look for? DRL module, relays, or switch or something?
Jan 23, 2007 at 2:00 AM
MATHIASO
  • 1,209 POSTS
there may be contact corosion in head lamp relay,
you have checked the ground allready,what about the fuse, head lamp connector, in-line connector
Jan 23, 2007 at 3:43 AM
2CARPRO JACK
  • 11,533 POSTS
Fuse 19 is left headlight power and 20 is right power. Be sure you have 12 volts through both fuses
Jan 23, 2007 at 3:53 AM
KCMANGOLD
THANK YOU!! The problem was a corroded fuse for the right side headlamp. THANK YOU AGAIN!!
Jan 23, 2007 at 5:13 AM
2CARPRO JACK
  • 11,533 POSTS
Happy to have saved you a trip to the shop
Jan 23, 2007 at 8:50 AM
Suggested Repair
Inspect and replace the corroded right headlamp fuse (fuse 20). Confirm 12 volts at fuses 19 and 20, and check the headlamp relay, grounds, and connectors if needed.
Conversation Summary
A 1998 Chevy Blazer had a dim right headlight after the bulbs and sockets were replaced. Experts suggested checking the headlamp relay, fuse, grounds, and connectors, and verifying 12 volts at fuses 19 and 20. The owner confirmed that a corroded right headlamp fuse was the cause.
