1991 chevrolet blazer has a tick
1991 CHEVROLET TRUCK
JUSTIN NEITZEL
  • 7 POSTS
i built a 383 stroker. it runs great. the problem is that it has a tick in the passanger head it sounds like a lifter we have adjusted them but the noise dont change. it has a rv cam in it. we checked if it was oiling, if a push rod was bent. and everything else i can think of
Jan 30, 2006 at 12:15 PM
2CARPRO JACK
  • 11,533 POSTS
might be a sticky valve in the guide
Jan 31, 2006 at 9:08 AM
JUSTIN NEITZEL
  • 7 POSTS
[quote:9be30a87af="2CarPro Jack"]might be a sticky valve in the guide[/quote:9be30a87af] if it was a sticky valve wouldnt it change when we adjusted it
Feb 1, 2006 at 6:13 AM
CHEVY350GUY
  • 109 POSTS
i would check the lifters. it could be insuficent oil to them which is why adjustments aren't working.
Feb 2, 2006 at 2:51 AM
JUSTIN NEITZEL
  • 7 POSTS
i figured out the problem the hypertech pistons were hitting on the spark plug bosses just barely. thanks for all the help
Feb 3, 2006 at 2:38 PM
