1991 Chevy Blazer Electrical Dies
COOPWC15
I have a 1991 blazer 4x4 with the 4.3 motor. I have replaced the battery, cables, and alternator. The car starts fine, idles just fine, but when ANY electrical is turned on i.e., wipers, blinkers, etc., there is hardly any power to run them. And as soon as I put the car in drive or reverse, the engine dies out like there is no power at all. Could this be a ground issue with the alternator or the battery ?? Thanks for your help
Apr 10, 2006 at 2:20 AM
LOSONE
  • 1,616 POSTS
You have a ground problem. Check the ground from the engine to the frame.(remove and clean) do the same with the engine to body ground as well as the engine to battery ground. let me know
Apr 10, 2006 at 10:52 AM
COOPWC15
losone... you were right on the mark !! thank you for your help, the blazer runs great now. Great advice for anyone who is also experiencing similar problems... check your grounds !!
Apr 12, 2006 at 1:00 AM
Suggested Repair
Remove and clean the engine-to-frame ground, the engine-to-body ground, and the engine-to-battery ground, then reinstall them securely.
Conversation Summary
A 1991 Chevrolet S-10 Blazer with a 4.3 engine started and idled normally after the battery, cables, and alternator were replaced, but accessories had little power and the engine died in drive or reverse. The expert identified a ground problem and advised cleaning the engine-to-frame, engine-to-body, and engine-to-battery grounds. The owner confirmed that cleaning the grounds resolved the issue.
