1996 Chevrolet Blazer Front Clunk
GM212
I am in need of help to find a clunking noise at low speeds in the right front, normally when backing up and turning (like backing out of a parking spot). I have replaced both front hub assemblies, upper and lower front ball joints, controll arm and shocks. (plus a lot more not related to this problem) A neighbor told me his Blazer starting the same thing right before he sold it and I have found others with the same issue on different forums, but no suggestions on what the fix may be. Any suggestions???
Apr 15, 2006 at 9:24 AM
LOSONE
  • 1,616 POSTS
Two or four wheel drive??
Apr 15, 2006 at 11:08 AM
SPONGER
  • 22 POSTS
did you check the CV joints?
Apr 15, 2006 at 2:04 PM
GM212
The Blazer is AWD, full time 4X4.
How do I verify if the CV joints are good or bad? Visual inspection looks good.
Apr 15, 2006 at 11:25 PM
SPONGER
  • 22 POSTS
If the boot is damaged, you pretty much definitely want to replace them. If the boot looks fine, there still could be some damage. CV joint work is not a simple task. You may want to take it to a shop (hopefully you have a mechanic "buddy") and tell them exactly what is happening, and you want them to tell you what is wrong. Don't make any guesses and don't tell them what you've already replaced. Keep it simple. They may charge you for up to an hour of labor time for a diagnostic fee, but it's probably going to be worth it to have a pro do it. Get a good estimate and think about it. Good luck.
Apr 16, 2006 at 9:51 AM
Suggested Repair
Inspect the front CV axles, especially the right side. Replace an axle if the boot is torn or the joint is worn. If the boots look intact, have a shop diagnose the low-speed turning clunk before replacing more parts.
Conversation Summary
The owner of a 1996 Chevrolet Blazer with full-time AWD reports a right-front clunk at low speed, mainly when backing and turning, after replacing hubs, ball joints, a control arm, and shocks. Replies suggest checking the CV joints: a damaged boot warrants replacement, but an intact boot does not rule out internal wear. Because CV work is involved, a shop diagnosis is recommended without steering the mechanic toward already replaced parts.
