1989 Chevy Truck
MACKTRUCK
  • 1989 CHEVROLET TRUCK
Electrical problem
1989 Chevy Truck V8 Four Wheel Drive Automatic
MY truck dose not run.
Wednesday, July 15th, 2009 AT 7:57 PM
If engine compression is good-check for fuel and spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, July 15th, 2009 AT 8:37 PM
