1984 Chevy Truck Wont start
LH1321
  • 1984 CHEVROLET TRUCK
  • V8
  • 64,000 MILES
I have a 1984 Pace Arrow Motorhome with a gasoline
Chevy 454 V8 engine, it won't start. I poured gasoline in carburetor and it fires and turns over but will not continue to run. I wondered if it might be
the fuel pump, bad gas, or carb problem, or just what might cause the problem. I did have it running
a few days ago, drove it for a test drive, returned home with it, kept it running (idled low like it was going to stall out) put weight on gas pedal to idle it up a bit) after a few minutes it stalled on own, repeated attempts to start it failed, batteries are ok.
Thanks for any help!
Saturday, June 14th, 2008 AT 10:57 AM
T won't start. I poured gasoline in carburetor and it fires and turns over but will not continue to run.
Check the fuel pressure and comeback with the readings this is where we start.
Saturday, June 14th, 2008 AT 11:56 AM
