WENT TO START IT AND IT WOULD NOT START SO I GAVE IT A JUMP WHILE JUMPING IT, IT BACK FIRED AND SPARKED UNDER THE HOOD WHAT COULD THIS BE?
Friday, November 21st, 2008 AT 6:29 AM
JDL
MECHANIC
Did you have the jumper cables hooked up correctly? Where did the sparking come from?
Check the battery and cables/wires, if that checks out, you can do some testing at the starter solenoid. Make sure the tranny is in park or neutral and the e-brake is set.
