1978 Chevy Truck starting problem
NEWKID101
  • 1978 CHEVROLET TRUCK
  • V8
  • MANUAL
  • 78,000 MILES
When I turn the key the truck wont even try to turn over at all the lights dont even dim a little bit and I have no clue whats going on
Wednesday, January 6th, 2010 AT 3:01 PM
JDL
  • 16,098 POSTS
Welcome to the forum, maybe a problem with clutch switch, where applicable. Any testing, make sure the tranny is in neutral and a functional e-brake is set. If your outside/under the vehicle, testing, if the tranny is in gear and the starter cranks, it will run over you or anything else in the way.
https://www.2carpros.com/forum/automotive_pictures/170934_chevy_truck_starter_circuit_1.jpg
Wednesday, January 6th, 2010 AT 3:23 PM
