1969 Chevy Truck V8 Two Wheel Drive Automatic
Could transmission fluid coming out of the vacuum modulator on a th 350 cause the truck to backfire and die when put into gear? The truck has a 305 in it. The truck was running when I bought it, but had a blown head gasket, before replacing the head gasket, the truck didn't have this problem. While the top half of motor was apart, I replaced the intake manifold with a Edelbrock performer, and put a Edelbrock 600 cfm carb on, and a new distributor cap and rotor. The truck will start and idle with a bit of a miss which causes the motor to jerk, I turned the distributor toward the front of the truck and it seemed to smooth it out a little, but when put in gear it backfires thru the carb, and then dies.
Could it be the vacuum modulator?
Thanks in advance.
SPONSORED LINKS
Saturday, October 25th, 2008 AT 12:44 AM
