The cheapest solution is to get all youre piston cyl's tested to see if you have a blown hd gasket, Also I would check each spark plug, When u pull them to pressure test the piston cyl, Also if everything checks out gooding that area, Also you could have a problem with youre carb, Or timing is off some degree's,
Good Luck.
SPONSORED LINKS
Wednesday, July 4th, 2007 AT 2:47 AM
