1960 Chevy Truck
VEZINA20
  • 1960 CHEVROLET TRUCK
  • V8
  • 150,000 MILES
I have a 350 V8 engine with a HEI distributor. The problem is that there is no spark going to the distributor when I crank the engine. When I ran a wire from the coil straight to the battery, it starts. What could be the problem?
Friday, November 7th, 2008 AT 6:47 AM
JDL
  • 16,098 POSTS
I saw your post yesterday, because you donated, I figured you would want one of the higher rated people to talk to you. I'm strictly shadetree.
Usually the B+ side of the coil is ignition feed, goes hot when you turn on the key. Whether the problem is the wiring or ignition switch, I can't tell from here.
You are saying, with the key turned on, there is no feed to the coil?
Saturday, November 8th, 2008 AT 8:41 AM
