thanks for your answer...
2005 Chevy Suburban 4WD Won't Shift
1 the switch itself
2 tccm transfer case control module
3 tcem transfer case encoder motor
the tccm is serial device so a reguar code reader cant check it , ive seen every part fail , not all at once , best advise is have it scanned for codes (the tccm) and see what happens
you can replace the switch and rule that out if you want , they are 25-30 bucks and install in minutes , but i am a big fan on diagnosing the problem and fixing it right the first time ,
one question i would like to ask is , when you start the vehicle do all of the lights on the switch blink then go out and one stays lit??
thanks
jim
Suggested Repair
Have the transfer case control module scanned for codes, since a regular code reader cannot access it. The mode switch, transfer case control module, and encoder motor can each fail. The switch is inexpensive and easy to replace to rule it out, but diagnosing the codes first is preferred.
Conversation Summary
The owner of a 2005 Chevrolet Suburban 1500 reports that the 2WD/4WD indicator randomly lights at startup and the system then stays locked in that mode, so the buttons cannot change drive range. The expert says the switch, transfer case control module, and encoder motor can all fail, recommends scanning the control module for codes, and notes the switch can be replaced cheaply to rule it out. The expert also asks whether all switch lights blink at startup before one stays lit.
