1993 Chevrolet Suburban Shift Shudder
JTHRNTN
Hello I have a 93 suburban 350 auto 158k the problem is the Transmission it was rebuilt by a reputable transmission shop that does good service, 8000 miles ago it had to have three separate trips after the first rebuild which were all covered under waranty. Now it intermiitently will actually shudder the entire truck seems to vibrate when shifting it doesn't happen all the time but it seems to happen more frequently when towing a load. The shop who completed the rebuild seems to think it is an electrical problem with the trailer wiring harness I have replaced this but still have the same problem. any ideas or am I going to have to replace this transmission I am tired of this thing constantly failing.
Jan 29, 2007 at 11:42 AM
2CARPRO JACK
  • 11,533 POSTS
Back to them again. unless all shifting is erratic, or at least something while not under load, then maybe. If it does this while towing, let them look at it again, somethings amiss
Jan 29, 2007 at 11:51 PM
Suggested Repair
Return the Suburban to the shop that rebuilt the transmission for reinspection, especially under towing load, since the shudder continues after the trailer wiring harness was replaced.
Conversation Summary
The owner of a 1993 Chevrolet Suburban reports intermittent shudder and vibration during shifts after a transmission rebuild, particularly while towing. The shop suspected the trailer wiring harness, but replacing it did not help. The expert recommends taking it back to the rebuild shop because something is still wrong.
