1993 Chevy Suburban Trans Slip, ABS Light
WANBOY
93 Suburban, While driving the ABS light will come on and the transmission feels like it is out of gear, I let up on the throttle and the trans engages again, the ABS light stays on. What do I need to be looking at for this problem?
Apr 13, 2006 at 4:15 AM
LOSONE
  • 1,616 POSTS
I don't think they are connected but you have a major tranny problem for sure. take it to a reliable tranny shop and let them check it out. I hope you have checked you fluid level as it will cause the same problem.
Apr 14, 2006 at 5:15 AM
Suggested Repair
Check the transmission fluid level first, since low fluid can cause the same slipping. If the problem continues, have a reliable transmission shop diagnose the out-of-gear condition; the ABS light may be a separate issue.
Conversation Summary
The owner of a 1993 Chevrolet Suburban reports that while driving the ABS light comes on and the transmission feels like it is out of gear. Letting off the throttle makes the transmission engage again, but the ABS light stays on. The expert does not believe the ABS and transmission issues are connected, says there is a major transmission problem, and recommends checking the fluid level and having a reliable transmission shop inspect it.
