1995 Chevrolet Suburban Brake Thock
MRS.LOPEZ
I need help please. When I push the brake and when I take my foot off the brake I hear a "thock" type noise. Someone told me I need the upper control arms replaced. Is that somwthing that would happen if the ccontrol arms need to be replaced? Also, when I turn there is a popping noise. Not all the time, mostly when I turn to the left. Any advise and help would be appreciated. Thank You.
Jun 11, 2007 at 3:26 PM
SERVICE WRITER
  • 9,123 POSTS
Bad CA bushings can do that, brake pad moving in the caliper can also do this. Have one person drive and brake (5mph at the most), while another gets a side view of the action. IF the wheel moves back in relation to the body, it is likley a control arm bushing problem.
Jun 11, 2007 at 11:22 PM
Suggested Repair
Have a helper watch the wheel from the side during a very slow brake application. If the wheel shifts rearward relative to the body, inspect the control arm bushings. Also check whether the brake pads are moving in the calipers.
Conversation Summary
The owner of a 1995 Chevrolet Suburban hears a thock when applying and releasing the brakes and a popping noise when turning, mostly to the left. They were told the upper control arms may need replacement. The expert says worn control arm bushings or brake pads shifting in the caliper can cause the brake noise, and recommends a low-speed side-view check for rearward wheel movement to confirm a bushing problem.
