1999 Chevrolet Suburban Stuck in Gear
CHEVROLET
GORDON
I have a 1999 chevrolet suburban 126,920 miles on the way home it quite shifting the transmission seems to be stuck in only first or second at the same time the speedometer quit can this be electrical and what should i check?
Thanks,
Gordonn
Dec 31, 2006 at 5:09 AM
MATHIASO
  • 1,209 POSTS
How is the gear oil? low? or contaminated?
Jan 1, 2007 at 3:40 AM
GORDON
[quote:fdd1330c08="mathiaso"]How is the gear oil? low? or contaminated?[/quote:fdd1330c08]
Jan 1, 2007 at 11:57 AM
MATHIASO
  • 1,209 POSTS
When the unit is locked in one gear, low or contaminated gear oil could cause the problem.
(thanks for answering my first question and been corporative :) )
Oil leaks at the speedometer drive can be caused by loose bolts or bad O-ring, and oil on the speed sensor wiring could cause it malfunction..
SHIfT LINKAGE PROBLEMS ,BOTH INTERNAL AND INTERNAL WILL ALSO CAUSE A TRANSMISSION TO LOCK IN A GEAR
STUCK INTERLOCK OR DETENT PINS OR BALLS WILL ALSO PREVENT THE DESENGEMENT OF A GEAR
Jan 1, 2007 at 12:45 PM
Suggested Repair
Check gear oil level and condition. Inspect the speedometer drive for leaks from loose bolts or a bad O-ring, and check whether oil has contaminated the speed sensor wiring. Also inspect internal and external shift linkage and stuck interlock or detent pins or balls that can lock the transmission in gear.
Conversation Summary
A 1999 Chevrolet Suburban with 126,920 miles stopped shifting and stayed in first or second while the speedometer quit. The owner asked whether the problem could be electrical and what to check. The expert said low or contaminated gear oil can lock the unit in one gear, that a speedometer-drive leak or oil on the speed sensor wiring can cause the sensor to malfunction, and that shift linkage problems or stuck interlock or detent pins or balls can also prevent a gear from disengaging.
