My question: is there any known electrical problem that these models have in common that I could have corrected? I've noticed that all the suburbans and trucks running lights burn out on one side, too. Is this possibly related? Many, many thanks!
2003 Chevrolet Suburban Blown Fuses
At the very least you need to find out so you can keep a few extra fuses so you don't get stuck.
What I do now is pack around a few of 5, 10, 15, 20, and maybe I have 25s too. These came in handy the last time this happened. Thanks
Suggested Repair
Have the fuel pump harness and connector inspected; a known GM truck issue can cause electrical failure of the pump. Replacing the connector usually requires lowering the tank. Confirm the connector concern with the dealer parts department using the VIN, and carry spare fuses until it is repaired.
Conversation Summary
The owner of a 2003 Chevrolet Suburban reports random stalling traced to blown fuses, including the cigarette lighter and fuel pump circuits, plus one-sided running lights. The expert says the fuel pump harness and connector were a common problem on many GM trucks and can contribute to pump electrical failure. The connector is typically replaced with the pump, which requires lowering the tank, and the owner should confirm applicability with dealer parts using the VIN.
