1995 Chevrolet Suburban Turn Signals Stay On
SUBURBAN2004
GMC / Chevrolet Suburban 1995
150.000 km
engine 5,7l
problem:
my turn lights stop flashing when switch on indicator switch. instead of flashing lights are permanently on. think it is the flasher relais but do not know where to find that part. the car has a trailer hook installed.
can somone help?
thanx
ralf
Jan 20, 2007 at 5:14 AM
BOOTDOG
  • 665 POSTS
under the dash on the left side next to the fuse panel. the flasher will look like a square. hope this helps.
Jan 20, 2007 at 7:26 AM
Suggested Repair
Locate the turn-signal flasher under the dash on the left side, next to the fuse panel. It is a square unit; inspect or replace it if the indicators stay on instead of flashing.
Conversation Summary
The owner of a 1995 Suburban with a 5.7L engine and a trailer hitch said the turn lights stay on instead of flashing when the indicator switch is used, and suspected the flasher relay but did not know its location. An expert said the square flasher is under the dash on the left side next to the fuse panel.
