the ignition wont turn when you put the key in the bells go off and the security light blinks but the key will not turn .
May 17, 2007 at 1:26 PM
Inspect the key for wear and try a spare key. If the spare also will not turn the ignition, replace the worn ignition key cylinder.
The owner of a 2002 Chevrolet Suburban reports that the key will not turn in the ignition, the chimes sound, and the security light blinks. The expert advises checking whether the key is worn and trying a spare key. If that does not work, the ignition key cylinder is likely worn and should be replaced.
