1996 Chevy Suburban
RONMILLER6113
  • 1996 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 188,000 MILES
Engine turns over, but will not start. Has had a tune up, replace fuel pump, before all of this, the engine wanted to die, lost power no exceleration, when applying gas peddal, it would back fire, miss, and check engine soon, light came on. Had autozone check the computer and it said oxygen censor right bank 1 was bad, I then replaced it. It ran fine for a day light went off on its own, the next day it ran fine and suddenly, it started doing all of these things again, autozone then checked again and the computer said 2 oxygen censors were bad, one of which I just replaced. Autozone said that it couldnt be the oxygen censors causeing these problems, they reset the code and it has yet to come back on, they believe its something eletrical or fuel, I have since gave it a tune up and replaced the fuel pump and stranier, it ran fine until two days later, I drove it somewhere it ran fine, once I parked and soon returned it will not start again, it just turns over, I have checked the fuses and replaced the fuel pump relay. What else could it be?
Monday, June 7th, 2010 AT 5:15 PM
HMAC300
  • 48,601 POSTS
Alot of times the crank sensor or cam sensor goes bad but won't put your service engine light on. You'll have to check the ohms on both and see if they are high. If they are that may be your problem. Use a new crank sensor to see waht ohoms that has then compare.
Wednesday, June 16th, 2010 AT 5:15 PM
