1996 Chevy Suburban fuel pump relay
ALJEN00969
  • 1996 CHEVROLET SUBURBAN
Electrical problem
1996 Chevy Suburban V8 Four Wheel Drive Automatic
It started about 9 months ago the fuel pump relay went out put in new one it was fine for about a week then went out again now it is getting hot and the wire from the relay to the pump looks like it is burnt a little. Checked the ground on fuel pump seemes ok it will run for about 1 hour then the relay is very hot and will burn out. I have put in 7or8 relays now and cant figure it out. And replaced the fuel filter
Friday, July 24th, 2009 AT 7:47 AM
JDL
  • 16,098 POSTS
Hello, do you have more than 1 tank on this vehicle? I don't know why it wouldn't blow the fuse, before it melted anything? Unplug the relay, see if the vehicle will still start and run? I'd use a gage and check fuel pressure, also check fuel pump amp draw. Is the fuse for the pump relay hot or anything?
Friday, July 24th, 2009 AT 9:22 AM
