HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Suburban
Fuel System
Fuel Pump
Relay
1996 Chevy Suburban fuel pump relay
BILLY107
MEMBER
1996 CHEVROLET SUBURBAN
V8
4WD
AUTOMATIC
178,000 MILES
I have gone through 2 fuel pump relays switches what would cause this?
Tuesday, March 25th, 2008 AT 8:46 PM
FISHERMAN
MECHANIC
What`s the time frame in between the replacement?
Did you opened the relays?
I mean to see if the problem its the contact burn because a high current drawn or the coil burnt.
If the contact is burn (arching) could be a high current drawning Fuel pump or a short to ground wire.
Let us know.
SPONSORED LINKS
Tuesday, March 25th, 2008 AT 9:34 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Relay Content
1996 Chevy Suburban Fuel Pump Relay
What Would Cause The Fuel Pump Relay To Get Power To Be Activated. The Fuel Pump Relay Has Been Tested And Is Good. There Is No Voltage To...
Asked by
hctucker
1996
CHEVROLET SUBURBAN
VIDEO
Replace Your Fuel Pump Relay - Easy Steps
Instructional repair video
Electrical Problem 1996 Chevy Suburban V8 Four Wheel Drive Automatic It Started About 9 Months Ago The Fuel Pump Relay Went Out Put In...
Asked by
aljen00969
1 ANSWER
1996
CHEVROLET SUBURBAN
1996 Chevy Suburban
Engine Turns Over, But Will Not Start. Has Had A Tune Up, Replace Fuel Pump, Before All Of This, The Engine Wanted To Die, Lost Power...
Asked by
ronmiller6113
1 ANSWER
1996
CHEVROLET SUBURBAN
Code 0200 Dtc, Fuel Pump Relay Fault
1) Challenged By 0300 Misfire Codes. Replaced, Plugs, Wires, Injectors. 150-155 Psi In Each Cylinder. 2) 0300 Remains And 0200...
Asked by
DHooper
5 IMAGES
2004
CHEVROLET SUBURBAN
1994 Chevy Suburban Fuel Relay Wont Work
I Have Replaced My Fuel Relay Plug And Relay Because My Truck Wont Prime Through The Relay. If I Jump The Orange Wire To The Gray The Pump...
Asked by
alaskalogger34
1994
CHEVROLET SUBURBAN
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Fuel Pump Replacement
Engine Not Starting
Online car repair manuals
