1999 Chevy Silverado Won't Start
MIRRO11
My 1999 V 6 Chevy Silverado worked fine w/o any troubles on Sat. On Sunday morning, it would not start. It turns over but does does not catch. I turn it over and over with no luck... Sounds like a fuel issue, but would that go so quickly. While starting it shutters a little and coughs but does not go. It did rain heavily on Saturday night and truck is out side.
Help..
Jan 8, 2007 at 1:56 AM
BACKYARDMECHANIC
  • 337 POSTS
With all the electronics in todays cars you are only a key turn from being stuck. Sometimes the parts just goes without any warning. To start I would go with the basics and check all the fuse particularly the fuel pump and ignition fuses. If they test good then you need to know if you have a fuel or ignition problem. When the motor cranks the problem is most of the time a fuel or ignition problem and in some rare cases its a timing issue. Check for spark at the plug wires . If there is no spark then you have a ignition problem but if you do have spark then its a fuel problem. Good luck :)
Sep 2, 2020 at 7:40 AM
Suggested Repair
Check the fuel pump and ignition fuses. If they are good, test for spark at the plug wires: no spark points to ignition, while spark points to a fuel problem.
Conversation Summary
A 1999 Chevrolet Silverado V6 ran fine Saturday, then cranked but would not catch Sunday after heavy rain, with some shuttering and coughing. The expert advised checking fuel pump and ignition fuses, then testing for spark to tell an ignition problem from a fuel problem.
