1999 Chevrolet Silverado Won't Start
TEEJAY103
  • 5 POSTS
Truck went through a period of not starting and it was random. It also just quit while driving down the road. We replaced the fuel filter, fuel pump (twice), and had the coil and rotor replaced. The electric wire that attaches to the rotor looks damaged. Could that be causing the truck to quit while driving or not to start? Is this something we can replace? If so, where can we get the part and diagram to replace the wires.
Oct 9, 2007 at 11:41 PM
SERVICE WRITER
  • 9,123 POSTS
We need to back up a bit and decide which is the faulty path- spark, fuel or both?
Shoot some carb cleanerl into the throttle body and se if it start for a moment. IF yes, its at least fuel.
Then hook up a spark tester and crank it checking for spark. IF no spark or fuel, there is a powertrain management problem or just spark issue most likley.
Post your results, we can go from there.
Coil and rotor?
Cap and rotor maybe?
Post a pic of the dameaged wiring as well.
Sep 2, 2020 at 7:42 AM
TEEJAY103
  • 5 POSTS
I started doing the suggestions, but found this was outside my abilities. I am taking the truck to a Chevy repair shop. I just hope the repairs don't cost more than the value of the truck.
TEEJAY103
  • 5 POSTS
The wire was broken in the connecter. We reattached it and now truck runs as good as ...well, as good as an old truck.
LOL
Now that we found and fixed that connection, I am wondering if the fuel pump, the rotor, and coil were really a problem at all.
Life is experience!?!
TEEJAY103
  • 5 POSTS
This turned out to be an experience with a $800 price tag
TEEJAY103
  • 5 POSTS
Also, I didn't have to take it to a Chevy shop. A neighbor that has a mom and pop fix it shop helped me. ($12.00 for wire, old part, and connector)
SERVICE WRITER
  • 9,123 POSTS
Glad to hear that you back in shape. I assume the connector at the fuel pump? Fairly common on those, but it didn't matter until we knew what it was lacking.
Stick with the mom and pop shop, more apt to get better service and fairer pricing.
Suggested Repair
Repair the broken wire in the connector and replace the damaged connector if needed. Confirm whether the fault is at the ignition or fuel-pump connector, and verify spark and fuel before replacing more parts.
Conversation Summary
A 1999 Chevrolet Silverado randomly would not start and sometimes quit while driving. The fuel filter, fuel pump, coil, and rotor had already been replaced, and a wire at the rotor looked damaged. The expert recommended isolating a fuel versus spark problem before replacing more parts. The owner later found a broken wire in the connector; after it was reattached with help from a local shop, the truck ran normally. The expert noted that a fuel-pump connector fault is fairly common on these trucks.
