1993 Chevy Silverado Bogging severely
TWEEKAGE
  • 38 POSTS
Oh. Well my o2 Sensor that I was told by three different shops that was in a good condition was my culprit. I haven't had a bog since. Pretty sure that mean my o2 sensor heated up is where it was giving the problems. Hence why the shops found it working fine off a cold start.
Tuesday, March 9th, 2010 AT 9:24 AM
RACEFAN966
  • 5,029 POSTS
Wow it must have had a short in it or something. You don't find many times where an O2 will cause this but that is great that you found it.
Wednesday, March 10th, 2010 AT 10:13 AM
TWEEKAGE
  • 38 POSTS
Yep:) But I still have some issues yet. Seems when I'm up around 60mph in 3rd gear. Sometimes it will hold back. And when that is doing that and I shift into O/D it will shake the truck. Same issue as before but now without the bog in the lower RPM range. So I elimiated one bog issue. Thought both were linked but apparently not. I'm probably going to check the timing again to verify that.
Wednesday, March 10th, 2010 AT 9:31 PM
RACEFAN966
  • 5,029 POSTS
Ok great place to start let me know what you find. It may be that we need to look at the TCM we will see.
Thursday, March 11th, 2010 AT 9:05 AM
Related Spark Plug Replace/Remove Content
