2005 Chevy Silverado Flutter when accelerating
2005 CHEVROLET SILVERADO
40,000 MILES • V8 • 4WD • AUTOMATIC
GRAYGHOST
I recently installed headers on my Silverado 5.3L. Around the same time, I also replaced my spark plugs and wires. I also installed a tuned chip. At first everything was great, I then started getting a fluttering noise after a couple of weeks. At first, I thought it was a gasket leak. I retorqued the header bolts to specs, and the collector bolts as well. I still have the noise. It only occurs when I'm accelerating , or the engine is under stress, going up a hill for example. Could this be a valve issue?
Jan 3, 2008 at 4:17 PM
Check for an excessive backpressure in the exhaust system-Catalytic Converter/Muffler/s.
Jan 3, 2008 at 10:58 PM
GRAYGHOST
[quote:a6fe297f87="rasmataz"]Check for an excessive backpressure in the exhaust system-Catalytic Converter/Muffler/s.[/quote:a6fe297f87]
Original question: Engine problem
2005 Chevy Silverado V8 Four Wheel Drive Automatic 40000 miles
FOLLOW UP QUESTION:
Here is my set up. 5.3L engine, no EGR, no A.I.R., K&N FIPK cold air intake, Granatelli cold air tuned MAF, Doug Thorley headers, Magnaflow high flow catalytic converters, Magnaflow catback exhaust single in dual out. I wouldn't think I'm suffering from back pressure issues. I'll check the backpressure, but if that is good, is there something else that could be causing the issue?
Jan 10, 2008 at 1:04 AM
Its hard to say what's causing it with all those modifications you've made. Could be just coming from the exhaust system.
Jan 10, 2008 at 8:47 AM
GRAYGHOST
[quote:314139a77e="rasmataz"]Its hard to say what's causing it with all those modifications you've made. Could be just coming from the exhaust system.[/quote:314139a77e]
Is it possible that between the cold air intake and the performance exhaust that I've overwhelmed the stock valves ability to move air in and exhaust out. I'm thinking that I may need to upgrade the heads and cam. Any thoughts?
Thanks again
Jan 14, 2008 at 12:08 AM
