2003 Chevy S-10 Flickering Lights
S10GIRL
I have a 2003 chevy s-10 with 50000 miles a 4 cylender I noticed while driving a night tonight the headlights flickered and also the interior light did the same they also did it wihile taping the brake what could be causing this I checked the bat cables it seem just fine
Jul 31, 2007 at 8:44 PM
CLY
  • 308 POSTS
I would start by checking the cables. Make sure they are clean and tight. Then I would check the alternator to make sure it is puting out the proper ampridge. It sounds like it isn't keeping up.
Cly
Jul 31, 2007 at 9:50 PM
Suggested Repair
Clean and tighten the battery cables, then test alternator output amperage; the alternator may not be keeping up with electrical demand.
Conversation Summary
The owner of a 2003 Chevrolet S-10 noticed the headlights and interior lights flickering while driving at night and when tapping the brake. The battery cables appeared fine. The expert recommended confirming the cables are clean and tight and checking that the alternator is producing proper amperage, suspecting it is not keeping up.
