2003 Chevrolet S-10 Turn Signal Out
SWATKAT
I have a 2003 S10 with about 29k miles on it.The right rear turn signal has gone out (wont flash)...but the bulb is good.The fuses are all good and the flasher is good.I swapped the bulb with a new one and nothing happened...also switched the old bulb to the left side and it was still good.The socket to the right rear is not getting any juice and I cant find the problem.I cant detect any moisture...there is no visible corrosion and no breaks in the wiring that i can find.The indicator in the dash flashes really fast as if a bulb were out but again, not the problem.I dont know where to look next and was hoping someone else may have the answwer...thank you!
Mar 24, 2007 at 11:27 AM
CHEVY22
  • 1,375 POSTS
if you have a test light check the bulb socket circuit further back , the brown wire is the power wire and can be followed up to the front of the truck , if you need more help post here
usually the sockets go bad
jim
Mar 26, 2007 at 12:35 PM
Suggested Repair
Use a test light to check the right rear turn-signal socket circuit farther back. Follow the brown power wire toward the front of the truck. Sockets commonly fail even without visible corrosion.
Conversation Summary
The owner of a 2003 Chevrolet S-10 reports that the right rear turn signal will not flash. The bulb, fuses, and flasher test good, and the socket has no power despite no visible moisture, corrosion, or wiring breaks. The dash indicator flashes rapidly. The expert advises testing the circuit farther back, tracing the brown power wire toward the front, and notes that sockets commonly go bad.
