1996 Chevy S-10 Turn Signals Out
jim
jim
jim
Suggested Repair
Confirm the bulbs are good, then locate the turn-signal flasher in the underhood power distribution center (marked on the cover) or, on some split-year trucks, under the right dash below the glove box. Swap it with the separate hazard flasher in the same area to test it.
Conversation Summary
A 1996 Chevy S-10 owner reports that the turn signals stopped working while the hazard flashers still work and the fuse is good. After confirming the bulbs were checked, the expert said the turn flasher is in the underhood power distribution box and is marked on the cover, with a separate hazard flasher that can be swapped to test it. The expert later noted that on some split-year trucks the turn flasher may instead be under the right dash below the glove box, depending on production date.
