1992 Chevy S10 Turn Signal Won't Cancel
1992 CHEVROLET
TONY2007
My dad had two extra lights put onto the bumper of his 1992 Chevy S10 Truck. He ran into my deck and broke one almost completely off. It was hanging on by one of the power wires. I'm thinking that he caused a short, because now there's no heat and the turning indicators don't work right. The left one doesn't return the indicator switch after a left turn, and the right one doesn't work, but the right arrow lights up when the lights are turned on.
Does anyone think that it's a short? If so, where is the fuse box on a 1992 Chevy S10 Truck?
I'm not sure what the engine size is, but I know that it's an extended cab. I think it has about 60,000 miles on it.
Feb 19, 2007 at 5:39 PM
2CARPRO JACK
  • 11,533 POSTS
The fuse box is by the drivers feet. If the switch wont "cancel" then it probably needs to be replaced, could also be the reason for the other side not working correctly
Feb 19, 2007 at 11:57 PM
TONY2007
[quote:22e99c3410="2CarPro Jack"]The fuse box is by the drivers feet. If the switch wont "cancel" then it probably needs to be replaced, could also be the reason for the other side not working correctly[/quote:22e99c3410]
Thanks.
Now the right one works, but the arm still has to be returned to the neutral position when I use the left indicator. I can live with that. However, If I can fix it for a small amount of cash that would be good. Any ideas?
Feb 20, 2007 at 9:37 AM
2CARPRO JACK
  • 11,533 POSTS
The return spring for the switch is broken, Need to disassemble the top of the column to replace it. Wont be very expensive even if a shop does it
Feb 20, 2007 at 11:10 AM
TONY2007
I'm glad. Thank you.
Feb 20, 2007 at 2:16 PM
2CARPRO JACK
  • 11,533 POSTS
you're welcome
Feb 21, 2007 at 4:14 AM
Suggested Repair
The turn-signal switch return spring is broken. Disassemble the top of the steering column and replace the switch; the repair should be inexpensive even at a shop. The fuse box is by the driver's feet if fuses need checking.
Conversation Summary
A 1992 Chevy S10 lost proper turn-signal operation after a bumper light was damaged and left hanging by a power wire. The owner suspected a short and also reported no heat. The right signal later worked, but the left signal still would not cancel. The expert located the fuse box by the driver's feet and said a switch that will not cancel needs replacement; the broken return spring requires opening the top of the steering column and should not be costly.
