1985 Chevrolet Astro Turn Signals Stay On Fix
CHEVROLET
WYMAN
I have a 1985 Astro van with approximately 169,000 miles. The left and right turn signal lights does not flash on and off, it stays on to the side the turn signal lever is switch to. The hazards light circuit functions okay. I've replaced all four bulbs and the turn signal still doesn't flashes. I've been told that there is a flasher unit that is part of the circuitry. If there is, I can't seem to locate it. I checked the fuse panel and I don't seem to see a flasher unit install. Can anyone tell me where it is located or does it uses one?
Thanks,
Wyman
Dec 28, 2006 at 9:49 AM
2CARPRO JACK
  • 11,533 POSTS
Yes it has one. Under the dash near the steering column.
Dec 28, 2006 at 11:38 AM
WYMAN
Thanks for the speedy response. You may need to elaborate more for me. I looked under the dash and close to the steering column. I can't seem to locate it. Do I need to remove anything?
Wyman
Dec 29, 2006 at 3:10 AM
SERVICE WRITER
  • 9,123 POSTS
To the right of the column, in a bracket, attached to the back of the instrument panel.
Dec 29, 2006 at 12:38 PM
Suggested Repair
Locate the turn-signal flasher under the dash, to the right of the steering column, in a bracket attached to the back of the instrument panel. Inspect or replace that flasher if the signals stay solid instead of flashing.
Conversation Summary
The owner of a 1985 Chevrolet Astro says the left and right turn signals stay on instead of flashing, while the hazard lights work and all four bulbs have been replaced. Experts say the flasher is under the dash to the right of the steering column, mounted in a bracket on the back of the instrument panel.
