1997 Chevrolet S-10 Headlights and Wipers
MMMGIXXER
1997 S10 4x4 ext cab ZR2 4.3 auto trans Having problems with the headlights and the wipers. Lights will not turn off with the daytime driving lights not disabled. (fuse pulled) While driving lights go out in dash, also sometimes the headlights themselves go out. Turn them off then back on stay on a little while. Also when lights flash the 4x4 lights for high low flash on and off. Sometimes when it rains the wipers stop working in any mode, fast or slow, delayed or not. I know its alot to ask in one thread but have you seen this before? Is the lighting problem connected to the on/off/daytime module? I have the number 15 drl/fog fuse pulled already. If I leave it in the lights wont go off when turned off. Hope you can help, I've tried to be as clear as possible.
Jul 3, 2007 at 4:02 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it could be the DRL module messing with you.Be sure nothing is blocking the light sensor located on top of the dash. The wipers sound like you need a Wiper Control Module, real simple fix, Chevy dealer will have a whole case of them in stock, common problem
Jul 7, 2007 at 1:16 AM
Suggested Repair
Check that nothing is blocking the light sensor on top of the dash, and suspect the DRL module for the headlight and dash-light issues. For wipers that stop in the rain, replace the wiper control module, a common failure available from a Chevy dealer.
Conversation Summary
A 1997 Chevrolet S-10 owner reported headlights that would not turn off with the DRL/fog fuse pulled, dash lights and headlights that went out while driving, 4x4 indicator lights flashing with the headlights, and wipers that sometimes stopped in the rain. The expert said the DRL module may be involved and advised checking that the dash light sensor is not blocked. The wiper problem was attributed to a failed wiper control module, described as a common and simple dealer repair.
