2001 Chevy S-10 truck will not start
MRMIKE1966
  • 2001 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 180,000 MILES
My s 10 will not start. Engine cranks, fuel pressure is good. Replaced fuel pump. Replaced injection spider.
engine will run for a few seconds if fuel is dumped into intake otherwise will not start. Ecm replaced.
Sunday, September 19th, 2010 AT 5:02 PM
Hi mrmike1966, Welcome to 2carpros and TY for the donation
Do a fuel pressure check -the specs is 60-66psi if okay
Check and test the fuel pump fuse, fuel pump relay and the fuel pump/oil pressure sending unit-
Sunday, September 19th, 2010 AT 5:59 PM
