2001 Chevy S-10 S-10 will not start, only turns over.
PANSON
  • 2001 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 13,000 MILES
I have an s10 with about 130k miles on it. I try and start it but all I get is the turning over. I can hear the fuel pump going on, and I get some sort of slow clicking while its turning over, but no on. Cables and plugs have been replaced but still nothing. What would be the issue.
Thursday, December 10th, 2009 AT 8:30 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, December 11th, 2009 AT 3:41 AM
