2001 Chevy S-10 01 Chevy S-10 Won't Start in the Morning
JDAVIS293
  • 2001 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 75,000 MILES
After sitting over the weekend my truck won't start on Monday mornings. After coming home from work 10 hours later, it starts right up this is the third week in a row. Tuesday through Friday, no problems. The engine cranks but doesn't turn-over. The battery is charged and the contacts are clean. I've changed the fuel filter twice and just tuned it up. Truck runs great except for Monday mornings. I don't know what it could be. I need help.
Monday, August 17th, 2009 AT 4:32 PM
WINEBURGER
  • 82 POSTS
Does it have a problem cranking or it will not start with exstensive cranking on monday
Monday, August 17th, 2009 AT 4:45 PM
JDAVIS293
It won't start with extensive cranking. I can keep cranking it until the battery starts to drain with no luck.
Monday, August 17th, 2009 AT 4:53 PM
WINEBURGER
  • 82 POSTS
The truck will need to be tested on monday morning to see if it has no spark or no fuel possible cause is the injectors bleeding off over the weekend. But it would normally start after cranking a few times
Monday, August 17th, 2009 AT 5:17 PM
BOBBING
  • 11 POSTS
You need to check to see if your getting spark. By the sounds of it, your Ignition Control Module needs to be replaced. That is the component that controls the coil.
Another thing is listen for the fuel pump. You should hear a buzzing sound coming from the gas tank. If you do not hear a buzz then your fuel pump is dead.
Wednesday, August 19th, 2009 AT 9:19 AM
BOBBING
  • 11 POSTS
I forgot to mention, listen for a click from the glove box when you turn the key to on. You should hear the fuel pump relay clicking. If not then that relay may be dead. There are 3 relays in the glove box. They are all the same kind. The fuel pump one is on the far left. The middle one is the horn. If the relay on the left does not click, switch it with the horn one in the middle.
Wednesday, August 19th, 2009 AT 9:23 AM
BOBBING
  • 11 POSTS
My bad, I didn't see you said it starts sometimes.
Well then it sounds like it could be the check valve/ball in the fuel pump that holds pressure in the line when the pump shuts off.
Wednesday, August 19th, 2009 AT 7:44 PM
WINEBURGER
  • 82 POSTS
Intermiten problems is one most difficult to diagnose. They have to be checked when the problem occurs to eliminate all the possibilitys to end up with the solution to your problem. If you check for spark and fuel see what you dont have and diagnose it from there.
Friday, August 21st, 2009 AT 8:31 AM
