2001 Chevy S-10 2001 wont start. Help!
RBURGESS2977
  • 2001 CHEVROLET S-10
  • 6 CYL
  • 120,000 MILES
I replaced the intake gasket. Reinstalled everything and car wont start. Found that coil was firing but was not getting spark out of the plug wires. Replaced the ignition rotor and distrubitor cap, now getting spark out of plug wore but engine still will not turn over. Car tries to start but just wont fire up. Timing seems to be correct but not positive. Could the timing being out a few degrees cause the car not to crank at all. Any ideas? Any input would be very appreciated.
Tuesday, May 27th, 2008 AT 9:01 PM
BLACKOP555
  • 10,371 POSTS
Timing a few degress off wont cause a no start, are all cylinders getting spark, and its not all erratic?
Dump gas in the throttle body, will that fire it up?
Tuesday, May 27th, 2008 AT 10:44 PM
RBURGESS2977
Getting spark off of all, dumped gas, did not work either. Wondering if there is a problem with fuel injection.
Wednesday, May 28th, 2008 AT 12:21 PM
BLACKOP555
  • 10,371 POSTS
Gas should fire it up if your getting spark.
Try a compression test, that should tell us if the valves are working properly.
Wednesday, May 28th, 2008 AT 2:43 PM
