My friends 74 Custom Deluxe Pickups timing is off. How do we go about resetting it?
350 small block
2 bbl
5.7 liter
350 small block
2 bbl
5.7 liter
Oct 20, 2006 at 5:27 AM
Use a timing light with someone experienced. With the engine running smoothly and not missing, start at 8-12 degrees BTDC and fine-tune from there. Avoid setting timing by ear; retarded timing can ping at low RPM and advanced timing can ping at higher RPM.
The owner asked how to reset ignition timing on a friend's 1974 Chevrolet Custom Deluxe pickup with a 350 small-block and 2-barrel carburetor. The expert recommended a timing light and experienced help, starting around 8-12 degrees BTDC if no high-performance modifications are present, then fine-tuning while avoiding pinging.
