1991 Chevy Lumina Firing Order
CHEVROLET
MBRUCE
I have a 1991 Chevy Lumina van with a 3.1 liter engine. I was changing the plugs and messed up the firing order. I have found the firing order, but I do not know which spark plug connection on the distrubutor cap is number one, which is number two,etc. Please help if you can. Thanks.
Dec 23, 2006 at 11:56 AM
HYKNRD
  • 59 POSTS
Some caps have some kind of markings for #1, some don't. If yours doesn't you can turn the engine over manually at the crankshaft(usually clockwise) until the timing marks align on zero. That should set the rotor at #1 position. But make sure by pulling the #1 spark plug and feeling for compression as the crankshaft nears the zero mark. Or pull the valve cover and check that both the#1 valves are closed.
Hope that helps
Dec 23, 2006 at 2:34 PM
BURRBRIAN
  • 158 POSTS
When you do get #1 cylinder on TDC see where your rotor is pointing at on the cap and #1 wire will go there, then going clockwise follow the firing order around the cap. Example- chevy v-8 is 1-8-4-3-6-5-7-2 firing order so after finding #1 you would take plug wire from #8 plug to the next place on the cap and continue through the firing order in this fashion. Having a 3.1 engine I believe is a v-6, isn't it? Two less plugs and wires to worry about. In the future if you only take 1 wire loose at a time you can avoid this confusion and keep it all in order. Good luck.
Dec 23, 2006 at 9:55 PM
Suggested Repair
Turn the crankshaft clockwise until the timing marks align at zero, then confirm cylinder 1 is on the compression stroke by feeling compression at the #1 plug or checking that both #1 valves are closed. With #1 at TDC, install the #1 plug wire where the rotor points and route the remaining wires clockwise in the engine's firing order. In the future, remove only one plug wire at a time so the order is not lost.
Conversation Summary
The owner of a 1991 Chevy Lumina van with a 3.1L engine mixed up the plug wires and knows the firing order but not which distributor-cap terminal is #1. Replies explain how to set the crank to TDC, verify #1 compression, place the #1 wire at the rotor, and continue clockwise through the firing order. A V8 order was given only as an example; the 3.1 is noted as a V6.
