1994 Other Chevrolet Models No Spark
1994 CHEVROLET
279,000 MILES • 6 CYL • FWD • AUTOMATIC
T_WANAMAKER
1994 Lumina APV mini-van, 3.8 L, cranks but won't start. No spark.
Engine ran OK until I replaced the lower intake manifold gasket, plenum gasket, and valve cover gaskets. I also replaced the radiator. From that point on, engine has had no spark.
The Ignition Control Module checks out OK. I replaced the Crankshaft Position Sensor too. Injector harness plugs show voltage across terminals on a voltmeter, but will not light a 12 volt test light. (I don't have a noid light).
I checked the fuses in the glovebox, they're all good. I suspect there are other fuses elsewhere, but I don't know where they're located.
Any ideas?
Thanks,
Tom
Jun 4, 2010 at 4:53 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 4, 2010 at 4:57 PM
  • 75,988 POSTS
Thanks for the negative feedback/vote I gave you something to work with a no spark problem. We're just in the very beginning of the diagnosis-Thanks-Request your refund
Jun 5, 2010 at 7:16 AM
