1995 Other Chevrolet Models timing
1995 CHEVROLET
JOTTE
Engine Performance problem
1995 Other Chevrolet Models V8 Four Wheel Drive Automatic
yea on a 95 chevy 2500 4x4 how can u tell if ur timing chain jumped tha truck well idle for about 20 second it sputters real bad if u put it to the floor it cuts outs and dies if u try to put it in drive it dies ive change distrubtor wires rotor spark plugs coil fuel filter
Mar 7, 2010 at 5:20 AM
HMAC300
  • 48,601 POSTS
first check your fuel pressure, if it's a prt fuel it should be about 45 p.s.i. if it's tbi it should be about 11. then to check to see if the chain jumped bring number 1 up to TDC and see where the rotor is pointing. It should point to numer 1 or very close to it. Number 1 is the first one on the left and it's about 11:30 on the dist cap.
Mar 11, 2010 at 12:08 PM
