1991 Other Chevrolet Models TIMING
1991 CHEVROLET
120,000 MILES • V8 • 4WD • MANUAL
JRG1950
What do I have to unhock before timing the engine
Nov 1, 2010 at 9:05 AM
HMAC300
  • 48,601 POSTS
disconnect the tan/black wire near the distributor. It should be a single wire hook up. then time the engien in the normal way it should be set at -0- for small block engines and -4- btdc for big block. you didn't put down what size the engine is, next time make sure to if you are asking an engine /powertrain question.
Nov 1, 2010 at 10:32 AM
