1997 Chevrolet Cavalier Heater Fan High Only Fix
CHEVROLET
BILL F
I have a 1997 chevrolet cavalier 4dr sedan , I believe 2.2 4cyl , my heater fan only works on the highest setting , I am asking for direction on replcing the fan motor. or other possible causes for the problem
Dec 19, 2006 at 3:15 AM
BOOTDOG
  • 665 POSTS
the problem is the blower motor (resistor) not the blower motor. it's gonna be somewhere close to the blower motor itself. locate the motor and follow any wires you see back the resistor, replace the resistor and all fan speed will work. good luck :)
Dec 19, 2006 at 3:22 AM
Suggested Repair
Replace the blower motor resistor located near the blower motor. Follow the wires from the motor to the resistor; replacing it should restore all fan speeds. The blower motor itself is not the likely cause when only the highest setting works.
Conversation Summary
The owner of a 1997 Chevrolet Cavalier reports the heater fan works only on the highest setting and asks about replacing the fan motor or other causes. The expert says the blower motor resistor near the blower motor is the problem, and replacing it should restore all fan speeds.
