1998 Chevrolet Cavalier Low Fan Speeds Out
MUSTANGMICKEY
Fan speed control...only works on 3 and 4 setting...1 and 2 do not work...not the switch, just replaced it. Is it a regulator or module? or what ever it is called...and where is it located so i can test it...or change it...Any help someone?
Jun 28, 2007 at 10:13 AM
E40WATER12
  • 522 POSTS
Hmmm, My friend just had fix that problem on his cavalier, I think its called heater fan transistor, Its located inside the heater fan.
Good Luck.
Jun 28, 2007 at 9:24 PM
BPRICE443
  • 66 POSTS
It is called fan speed resistor the power goes through different resistors depending on the posistion of the switch. I am not sure where it's located on your car but it is by the fan motor most of the time.
Good luck
brian
Jul 3, 2007 at 5:26 PM
Suggested Repair
Test or replace the blower motor resistor, also called the heater fan transistor. It is typically located at or inside the heater blower motor.
Conversation Summary
The owner of a 1998 Chevrolet Cavalier reports that blower fan speeds 1 and 2 do not work, while speeds 3 and 4 do. The fan switch has already been replaced. Replies identify the blower speed resistor or heater fan transistor, located at or inside the heater fan motor, as the likely part to test or replace.
