The AC fan hardly blows on the first and 2nd setting, but works well on the 3rd and 4th seting
Where is the fan located and how do I replace it.
The blower motor is likely fine. Check and replace the blower motor resistor at the evaporator case under the right side of the dash, which controls fan speed. Also check the blower motor relay in the engine compartment fuse/relay center. Labor is about 0.7 hours; parts cost was not given.
A 1996 Chevrolet Cavalier owner reported the AC blower barely works on the first and second speeds but works well on the third and fourth, and asked where the fan is and how to replace it. The expert said the motor is probably fine and the resistor between the switch and motor is the likely cause. The blower is on the right side of the dash and the resistor is at the evaporator case under the right side of the dash. A follow-up asked what the resistor is, whether it can be replaced, and the cost. The expert explained that the resistor varies resistance to control motor speed, said it can be replaced if bad, noted the relay location, and estimated about 45 minutes of labor without a parts cost.
